If I understand correctly
You have a point at an x,y,z
You would like to have a block at this location..
One way I do this is:
export points as a shape file.
open a new drawing
paste your desired block into the new drawing
delete the block the block from the new empty drawing (you only need the
definition)
import the shape file into an empty drawing and tell map to use the block on
the point. (it is available in the shape file import process)
You now have a block at the x,y,z where the point location in the new
drawing.
once everything looks good you can insert the new drawing into the orginal
as a block and explode.
"Paolo"
wrote in message
news:366BD20C54A44921F9807FF311A7B002@in.WebX.maYIadrTaRb...
> Is it possible to place a BLOCK in the xyz coord of a POINT?
> Which is the correct query?
> This is my problem:
> I've got to Z place a lot of blocks representing trees. Their elevation is
> zero, now.
> Above these blocks I've got points placed in the correct Z position (where
> the blocks must placed).
> How can I do?
> I tried a lot of queries but without results.
> I'm thinking to create a buffer around the points, intersect the points
with
> the buffer and catch the elevation object data, create a plygonal topology
> with the blocks....
> I think there's a shortest way using Map.
> Thanks in advance
> Paolo
