AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Photo GeoTagging in Map 3D
11 REPLIES 11
Message 1 of 12
1887 Views, 11 Replies
I have survey data points that have had photos taken from the data collector of items surveyed.  The photos are attacted to points in Trimble Business Center.  I will bring this survey data into Map3D 2013 and ultimately to a SHP and SDF files.  Is there a way for me to either keep the photo attacted to the point or associate it in one of the other file formats?
Tags (2)
11 REPLIES 11
Message 2 of 12
antoniovinci
That's a great question, sir.
Is your Trimble software able to export those points as shapefile with attributes..?
Message 3 of 12
in reply to: antoniovinci
Yes, Trimble Business Center can export out a shapefile with attributes.
How does that get me closer to a solution.
Message 4 of 12
antoniovinci
Please zip and attach 1 shapefile with 1 photo, I'd like to check its structure.
Message 5 of 12
Here's a zip containing the shapefile an image.  The survey point associated with the image is;
Most points in my survey file have images associated with them in TBC.
-Chris
Message 6 of 12
Murph_Map
Document view is one way, depending on the fields and image names you make be able to get the link/image name when you export out of Trimble. http://map3d.wordpress.com/2010/06/23/using-autocad-map3d-document-view/
Murph
Supporting the troops daily.
Message 7 of 12
antoniovinci
Unfortunately I cannot find any common ID between the shapefile and the EXIF info embedded in the photo, so I give up, sir.
Message 8 of 12
Can you tell me how to view EXIF info?  I'm working on correlating the photo and point in TBC which should give a 1 to 1 match.  How do you open the photo to view the EXIF?
Message 9 of 12
antoniovinci
I use the free Irfanview (click the blue "I" icon, or simply press the "I" key).
Message 10 of 12
TerryDotson
As AV mentioned, there is no common ID and no GpsLat/Long in the EXIF (which even an iPhone includes) so there is no way to tie them together with what you have provided.  No chance of automation.
Since you knew the image was at point 16367 is that recorded in another file (sadly the big T didn't export it with the Shapefile) ?
Message 11 of 12
in reply to: TerryDotson
Let me look into that.
Message 12 of 12
sorry to say, but the foto you have attached does not have locations in the exifsdatasets. otherwise you could use the geophotoextension:
https://www.youtube.com/watch?v=zrsJs8c7t9U
best regards
”Boost
