I have survey data points that have had photos taken from the data collector of items surveyed. The photos are attacted to points in Trimble Business Center. I will bring this survey data into Map3D 2013 and ultimately to a SHP and SDF files. Is there a way for me to either keep the photo attacted to the point or associate it in one of the other file formats?
That's a great question, sir.
Is your Trimble software able to export those points as shapefile with attributes..?
Please zip and attach 1 shapefile with 1 photo, I'd like to check its structure.
Here's a zip containing the shapefile an image. The survey point associated with the image is;
Most points in my survey file have images associated with them in TBC.
-Chris
Document view is one way, depending on the fields and image names you make be able to get the link/image name when you export out of Trimble. http://map3d.wordpress.com/2010/06/23/using-autocad-map3d-document-view/
Unfortunately I cannot find any common ID between the shapefile and the EXIF info embedded in the photo, so I give up, sir.
Can you tell me how to view EXIF info? I'm working on correlating the photo and point in TBC which should give a 1 to 1 match. How do you open the photo to view the EXIF?
I use the free Irfanview (click the blue "I" icon, or simply press the "I" key).
As AV mentioned, there is no common ID and no GpsLat/Long in the EXIF (which even an iPhone includes) so there is no way to tie them together with what you have provided. No chance of automation.
Since you knew the image was at point 16367 is that recorded in another file (sadly the big T didn't export it with the Shapefile) ?
sorry to say, but the foto you have attached does not have locations in the exifsdatasets. otherwise you could use the geophotoextension:
https://www.youtube.com/watch?v=zrsJs8c7t9U
best regards
