AutoCAD Map 3D General Discussion
braudpat
Message 11 of 13 (78 Views)
Re: Phantom OD Attached?
02-27-2014 11:47 AM in reply to: Gary_Braun
Hello
SORRY you right : I don't read correctly your post !
So during the MAPEXPORT, you must add the .ROTATION AutoCAD property : you will get the Rotation in Radian inside the SHP (or TAB or MIF-MID)
Then MAPIMPORT and you will get the Blocks and all the fields in OD (with the famous Rotation in Radians)
I know that all blocks are NOW horizontal !
Next step :
From a blank DWG (beware of the Units) you will use the drawings Group feature of MAP
and then you will define a Query that will draw the F204 block with a New rotation coming the Object Data field ROTATION !
Do you see that I mean ?
Bye, Pat
Bye, Pat
Valued Contributor
Gary_Braun
Message 12 of 13 (73 Views)
02-27-2014 12:00 PM in reply to: braudpat
I do see what you mean. It's an extra step or two but should get me what I need.
I'll let you know if I have further problems.
Thanks for your time Pat.
braudpat
Message 13 of 13 (69 Views)
02-27-2014 12:11 PM in reply to: Gary_Braun
Hello (Sorry for my bad US/English)
Sorry I have forgotten something ... The RADIANS "problem" !
In the blank DWG, please : UNITS are correct --- BUT you must set temporary the angle system as RADIANS !!
So when you will do the Query (in Draw mode) and says draw with a new rotation
coming from the MAP Object Data field ROTATION (which is in Radians) : NO PROBLEM !
After the Query in Draw Mode, you will set back the angle system to decimal or grads ...
I hope this will satisfy your needs !?
I am often doing this for the lack of ROTATION when doing MAPIMPORT ... If I have the ROTATION Info !?
Bye, Pat (Maybe a Kudos will be appreciated)
Bye, Pat
