AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Pb with command _MapPolylineToPolygon
5 REPLIES 5
olivier.eckmann
440 Views, 5 Replies
I've MAP 3D 2013 64 bit (French version) with SP1.
When I launch command to "Convert polyline to polygon" (_MapPolylineToPolygon), I've message on command line "Select objetcs", I can convert to polygon =>OK
If I launched this command a second time, I've no possibility to select object, I come back to command line.
I quit MAP, then launch MAP, and I can use this command only 1 time.
This problem appears after SP1 was applied.
Could someone reproduce this problem? Have you got a solution?
thanks
Olivier
5 REPLIES 5
I can't, since I'm a poor 2006 user, but... what about using the _MPOLYGON command instead?
already confirmed >>>here<<<.
(you would have found by yourself using the search >>>click<<<, currently the second item of the list of found links 😉 )
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Sorry for not searching before posting.
Olivier
No problem 😉
- alfred -
Alfred NESWADBA
Hotfix has been published to correct this problem.
HotFix
Olivier
”Boost
