I created some tables in the attached AutoCAD Map 3D 2011 drawing by copying and pasting cells from an Excel 2007 workbook.
I have been able to update the tables in AutoCAD and print without any problems. However, when a second user opened the drawing, the table text was missing (the lines were present).
Any idea what may be wrong with the drawing and how to fix it?
Note: We are saving our files in AutoCAD 2010 format for compatibility with some LT users.
Do both machines have the same level of ODBC drivers installed?
Check Control Panel - Administrative TOols - Data Sources - Drivers Tab - see if the version is the same for both.
I'm running Windows 7 64-bit and he is running Windows XP. I will check on the drivers.
