AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
paper space everything is black
3 REPLIES 3
216 Views, 3 Replies
I am using Map 5
When I go to paper space to plot my layout all the drawing is black. When I
plot, everythings plots fine but on the screen everything is black. If I
remake the layout all the layer colors show properly. This just started to
happen.
thanks
3 REPLIES 3
Is it possible that your viewport has had some specs attached to it? Does it help to erase the viewport and then create another 'clean' one?
That is all I can think of at the moment.
Check in the page setup/plot dialog and see if Display by Plotstyles is
checked.
Murph
"vicki coleman" wrote in message
news:4822222@discussion.autodesk.com...
>I am using Map 5
> I
> to
> happen.
> thanks
Try typing ps when it is all black to return to paperspace.
I am guessing that you are doubleclicking on the viewport border and
inadvertently issuing the command vpmax.
>I am using Map 5
> I
> to
> happen.
> thanks
”Boost
