AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Overlapping dashed polyines look solid.
1 REPLY 1
tgilks
1244 Views, 1 Reply
Is there anyway to line up the dashes of overlapping polylines so that when I have 2 or more dashed polylines on top of each other the polyline will still looks dashed. Because at the moment the dashes don't line up and the polyline appears as a solid line where they overlap. Thanks.
1 REPLY 1
nwray
in reply to: tgilks
I am assuming that both polylines have the same linetype...
From my own experiences with this, you need to look at two things.  First, make sure that the linetype scale is the same for both polylines.  Then, you either need to match up the vertices of the polylines, or make them sufficiently far apart that the pattern repeats itself with the same frequency.
Norm
GIS Specialist
BOXX Technologies APEXX 2 2402 Workstation
Intel Core i7-6700K @ 4.4 GHz
32 GB RAM / 500 GB SSD
NVIDIA Quadro M2000 Graphics
Windows 7 Pro 64 bit C3D 2017
”Boost
