AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Output Plot no showing up in Preview
2 REPLIES 2
DTompkinsPretivm
797 Views, 2 Replies
I'm having a plotting issue with one of my drawings.  It's not showing up on plot preview, or even when I print it.
Any other drawing I create under the same Page Setup print fine.  The paper and viewport have been have been set up for a standard 8x11, and drawing appears in as normal in the viewport.  The layers are ok with no attributes (i.e transparency)  set as to affect the print output.  The printer drivers are up to date, and really doesnt make sense as any drawings I create under the exact settings show up normally and print out with no problem. Really don't want to recreate the drawing from scratch, so any help would be greatly appreciated
AutoCAD Map3D 2012
2 REPLIES 2
open your layer-manager, you'll recognize that the layers
  • BUILDINGS
  • DIMENSIONS
  • GRID
have been set to "no plot" 😉   (printer symbol has a small red "no"-sign in front)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Wow, I'm a fool.
I never paid attention to the plot option in layer-manager. Assumed it was defaulted to on.
Thank you so much!!
”Boost
