AutoCAD Map 3D General Discussion
Murph
Message 11 of 23 (157 Views)
Re: osnap pick prioritizing.
03-22-2012 02:50 PM in reply to: stevedb
I've been watching this thread to see how far it gets off the orginal question. There is a thing called cycleing but if you think right-click is to much then so is that. Back when I had users that didn't like the osnap and using it I create a simple macro or lisp to set it as needed then reset it back after they finished drawing the line or what ever.
Murph
Supportting the troops daily.
Valued Contributor
stevedb
Message 12 of 23 (156 Views)
03-22-2012 02:54 PM in reply to: Murph
ok Murph.
since you said it.... lets have this cycling thing.
At this point, I'm sufficiently intrigued, and ready for new stuff that I figure that knowing is better than just being told there's another toy, but you won't like it.
So, please...
go for it.
TYIA.
Distinguished Mentor
thepworth
Message 13 of 23 (153 Views)
03-22-2012 03:01 PM in reply to: Murph
What! we never wander off topic.... oh, wait where was I...
Say, if i mentally have to subtract out the highest & work my way down from the base 2 settings for osmode, think the software has to process the same way?  would be strange but...
Also, I recall LDD days where the software was notorious for disabling Osnaps, but not renabling when the routine completed or if it crashed... If we have priority for inferring constraints, why not for osnaps????
C3D 2011
Intel Xeon E5630@2.53Ghz
NVIDA Quadro NVS420 Dual Monitor
12GB Ram / Win7 Professional 64bit SP1
Murph
Message 14 of 23 (152 Views)
03-22-2012 03:05 PM in reply to: stevedb
stevedb wrote:
ok Murph.
So, please...
go for it.
TYIA.
Press the TAB key when it asks for the point.
http://autocad.autodesk.com/?nd=autocad_tips_tutorials_detail&adsk_tip_id=942
Murph
thepworth
Message 15 of 23 (150 Views)
03-22-2012 03:07 PM in reply to: Murph
Sweet!  learned something new!
C3D 2011
Murph
Message 16 of 23 (148 Views)
03-22-2012 03:12 PM in reply to: thepworth
And to think I didn't have to bill you for it.
Maybe that's why I'm sitting here eating a frozn pizza for supper instead of a home cook meal.
Murph
Valued Contributor
stevedb
Message 17 of 23 (143 Views)
03-22-2012 03:59 PM in reply to: Murph
Ok, I must be missing something.
I click the tab button and it cycles back and forth from the distance to the angle.
ok... I just did it again, this time overlying an endpoint, and I began to see where it appears to cycle through the active osnap elements. Is this what you're talking about?
definitely-- you should be enjoying a homecooked meal. Eating frozen pizza will catch up to you in your 40's and 50's.
thepworth
Message 18 of 23 (141 Views)
03-22-2012 04:00 PM in reply to: stevedb
I suppose you have dynamic input enabled - try turning it off from the buttons on the bottom of the screen
C3D 2011
thepworth
Message 19 of 23 (139 Views)
03-22-2012 04:01 PM in reply to: Murph
Here's the local brew to go with your pizza... :smileywink:
C3D 2011
Murph
Message 20 of 23 (134 Views)
03-22-2012 04:07 PM in reply to: stevedb
Yes, the osnap cycleing. Told ya you may not like it.
I'm past those numbers already :smileyhappy:
Murph
