AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
OpenOffice - Database NOOB question
3 REPLIES 3
thepworth
386 Views, 3 Replies
From what I see, if I set up an OO.Base, I can't set up an ODBC connection to us it in Map3D.  Is this correct, or does anyone have a pointer (other than MySQL / Oracle)?
Thanks!
3 REPLIES 3
NateMoore
in reply to: thepworth
yes, as far as I have found there's no ODBC options for open office.However, http://wiki.services.openoffice.org/wiki/Database#Connecting
and http://wiki.services.openoffice.org/wiki/Base_New_Driver_Tutorial  looks hopeful, I just didn't work through it enough to say for sure.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
thepworth
in reply to: NateMoore
Thanks, Nate.  When I looked at the OO web before my posting, the 2008 help there indicated it was a "closed issue" of low priority as only 11 folks voted positive for it.  What would it take to push for FDO to OO - M3D wishlist or elsewhere in the OpenGIS forumns?
Todd
NateMoore
It's probably best to push for it on the Open Office side of things - once there's an ODBC connector, Map and everything else will just see it in the ODBC list, same as the Access, SQL, etc options that are now available.  Of course, it never hurts to ask on OSGeo...
Nate Moore, GISP
Global Services
Autodesk, Sarl
”Boost
