"Volker Cocco" <
href="mailto:vcad@alaska.net">vcad@alaska.net> wrote in message
href="news:315F8520A3527419F60D9DF950092A72@in.WebX.maYIadrTaRb">news:315F8520A3527419F60D9DF9500......
So this morning I'm working away (in Map 2004),
entering commands through the CLI. While in the offset command I made a
mistake (I still find that part hard to believe <g>), instead of
cancelling the command or hitting enter to follow through and do an undo, I
typed U while still in the Offset command.
I then glanced at the command line and noticed
the prompt "Expects a point or CLass".
Specify offset distance or [Through]
<0.0312>: .375
Select object to offset or <exit>:
Specify
point on side to offset:
u
*Invalid selection*
Expects a point
or CLass
size=2>
I'm feeling a bit dumb here. I've never
noticed this before. What CLass are we referring to here? "Remedial AutoCAD
Command Basics 101"?
Cheers!
Volker
"Marion Pietsch" <
href="mailto:discussion.support@autodesk.com">discussion.support@autodesk.com>
wrote in message
href="news:88D00C85FE8910AED585866C71C54669@in.WebX.maYIadrTaRb">news:88D00C85FE8910AED585866C71C......
Volker,
it's not you being dumb 🙂 There are no
classes in AutoCAD.
I can reproduce and it's also happening in
plain AutoCAD. To me it looks that by mistake an error message related to
Map functionality (Classifications) was implemented here. However, the
command works properly, just the message might be confusing.
face=Verdana size=2>
Thanks for reporting this.
Marion Pietsch
Autodesk Professional Services
Infrastructure Solutions
"Volker Cocco" <
href="news:315F8520A3527419F60D9DF950092A72@in.WebX.maYIadrTaRb">news:315F8520A3527419F60D9DF95......
2004), entering commands through the CLI. While in the offset command I made
a mistake (I still find that part hard to believe <g>), instead of
noticed the prompt "Expects a point or CLass".
<0.0312>: .375
Specify
u
*Invalid selection*
Expects a
point or CLass
size=2>
Cheers!
size=2>Volker
