Do you have a unique field in the data as the KEY field? What format is the
ODBC connection to (txt file, dbf, etc.)?
Murph
http://map3d.wordpress.com/
"DanielGarrett" wrote in message news:6336762@discussion.autodesk.com...
I have an ODBC Data connection in Autocad Map. I'm pulling in data
information about my company's land parcels. And for each Parcel there is
anywhere from one to four lines of data. The problem is, for each of these
lines of data, it should have example, " Report A", Line two should have
"Report B" and so on. But when I connect to the table. It has multilple
lines of data, but they all have the same thing from the first line. So it
just repeats it's self. But I can pull the same data set into ArcInfo and it
has all the mulitiple lines of data. You just have to have ArcServer to do a
One to many join. Any help or ideas would be greatly apprecitated.
- Dan
