AutoCAD Map 3D General Discussion
Valued Contributor
farad51
Message 1 of 7 (199 Views)
OD-ROADS
199 Views, 6 Replies
03-31-2012 12:44 AM
I am going through autocad map tutorial and trying to export Redding map .dwg to sdf format....when openning the properties of ROADS ...at the bottom of the properties table you get something like that:
OD-ROADS
Lentgth....
Name...
ST_Name...
ST_type...
So my problem is how you do to put  the OD  in the properties there? can someone guide me?
Valued Mentor
parkr4st
Message 2 of 7 (196 Views)
Re: OD-ROADS
03-31-2012 02:09 AM in reply to: farad51
when you export select the feature class tab, select attributes button and select properties and object properties you want to be object data for the sdf objects.
Valued Contributor
farad51
Message 3 of 7 (192 Views)
Re: OD-ROADS
03-31-2012 05:01 AM in reply to: parkr4st
THANKS.,,,Mr parkr4fst
but the problem is do i have to make table for those details?
Valued Mentor
parkr4st
Message 4 of 7 (189 Views)
Re: OD-ROADS
03-31-2012 05:15 AM in reply to: farad51
Data connect to the sdf and open the data table.
back up a bit and tell us  your original roads are autocad polylines or line with object data attached?  If so, then that data becomes the data in the sdf file.  If not then you have not data in the table.
Valued Contributor
farad51
Message 5 of 7 (179 Views)
Re: OD-ROADS
03-31-2012 10:17 AM in reply to: parkr4st
after checkiing I found that most of the lines are polylines and some are simply line
Valued Mentor
parkr4st
Message 6 of 7 (165 Views)
Re: OD-ROADS
04-01-2012 02:44 AM in reply to: farad51
selct a pline or line and check the properties.  Ctr1 or right click and properties.  at the bottom of the properties you have OD:nameofdatatable.  Are there values in the right column of the OD?
If so this is exported to the sdf when you select to do so in the export process
Valued Contributor
farad51
Message 7 of 7 (154 Views)
Re: OD-ROADS
04-01-2012 10:08 AM in reply to: farad51
Thanks a lot for assistance
