AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
OBJECT DATA NOT APPEARING IN REPORT
2 REPLIES 2
rferguson7
272 Views, 2 Replies
I created a new table with object data and I want to create a report with the new object data I have assigned to my objects but when I create the report, the fields I have selected in my report template are not showing at all...they just show as ,,,, and then the one property I chose, length shows after that. each line looks like this:
,,,,,932.80233538508958
What am I doing wrong?
2 REPLIES 2
antoniovinci
in reply to: rferguson7
1] first _MAPEXPORT all to a brand new shapefile
2] then open an empty drawing, and _MAPIMPORT that shape
3] run again your report routine
rferguson7
in reply to: antoniovinci
that did it. Not sure I understand why that has to be done but I'm happy to have it working. I guess I can see the benefit would be so that I can create reports for drawings that others can still be working on. I am using this for the first time to create a complex construction cost estimate and I really like the potentital I see of using MAp versus Civil 3D. THanks for your help!
”Boost
