AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Object Data Attachments
5 REPLIES 5
304 Views, 5 Replies
Hello
2 questions re Object Data Attachments
1) We want to attach dwg files as documents to object data but find that this method launches another session of AutoCAD. Is it possible to have this drawing file open in the current session?
2) Similarly we are attaching Word Documents to object data but the document fails to open because there are spaces in the path name. Is there a setting that controls spaces in path names or do we have to change our directory names?
Many thank for any answers,
Neil Carstairs
Cartographical Surveys Ltd.
(UK)
5 REPLIES 5
Would a simple hyperlink work better for
you in either situation?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hello
session?
directory names?
Neil Carstairs
(UK)
Tried that, so next question is,
with pickfirst set to 1 and both hyperlink
options checked on how do I pull up the
hyperlink menu (the hyperlink attach worked fine)
Neil Carstairs
(UK)
Hi,  Did you try enclosing the path
in double quotes. I remember it worked for me some time back..
Hello
session?
directory names?
Neil Carstairs
(UK)
Select the object, right click, and it should be at
the bottom of your right click menu, unless you have right click configured to
repeat the last command, then I am not sure.
Tried
attach worked fine)
Neil Carstairs
(UK)
I think I have sorted this.
Pickfirst needs to be 1, both
hyperlink boxes need to be ticked
and then tick on the Windows Standard
Behaviour option for Shortcut Menus in
Drawing Areas. The Hyperlink menu then
appears as part of the short cut menu.
Neil Carstairs
”Boost
