AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Object Data and RUS Imperial
3 REPLIES 3
361 Views, 3 Replies
I am using the Place Pole command in AUD.  I want to define object data and use RUS Imperial, but maybe I shouldn't do both.  My goal is to set default pole height, class, and top.  When I use Place Pole, the height and class are fine for existing but I need a different class as a new pole default.  Possibly adding a conductor will generate pole tops.
P.S. General information is great.  I will be posting this on the AUD forum for specific information.
3 REPLIES 3
JeffPaquette6500
Hi Donald,
Once you place a pole in AutoCAD Utility Design, you can view/edit Feature information. The following help file explains this process in more detail:
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-935D5223-C908-49FC-A0CE-7EEEBB530909.htm
After you attach overhead conductor, the pole head will be determined by AUD.
Jeff Paquette
Data Management Support Specialist
Autodesk, Inc.
in reply to: JeffPaquette6500
Can I change the symbol display before using the Place Pole command?  What are the best steps to take if I want a Display Manager layer for poles?  I already have symbols I prefer based on pole status.  I need to use something besides the Display Manager?
Maybe there should be a symbology setup tool.  I don't know.  It has turned out that AUD in less user-friendly for me than I originally thought it would be.
”Boost
