I am using the Place Pole command in AUD. I want to define object data and use RUS Imperial, but maybe I shouldn't do both. My goal is to set default pole height, class, and top. When I use Place Pole, the height and class are fine for existing but I need a different class as a new pole default. Possibly adding a conductor will generate pole tops.
P.S. General information is great. I will be posting this on the AUD forum for specific information.
Hi Donald,
Once you place a pole in AutoCAD Utility Design, you can view/edit Feature information. The following help file explains this process in more detail:
http://docs.autodesk.com/UTLDESN/2014/ENU/filesAUDUG/GUID-935D5223-C908-49FC-A0CE-7EEEBB530909.htm
After you attach overhead conductor, the pole head will be determined by AUD.
Can I change the symbol display before using the Place Pole command? What are the best steps to take if I want a Display Manager layer for poles? I already have symbols I prefer based on pole status. I need to use something besides the Display Manager?
Maybe there should be a symbology setup tool. I don't know. It has turned out that AUD in less user-friendly for me than I originally thought it would be.
