AutoCAD Map 3D General Discussion
Member
0 Kudos
Post 1 of 8
No layer properties dialog box
2091 Views, 7 Replies
04-29-2011 01:35 PM
Hitting the layer properties button puts it in "cursor" type mode.  No dialog box appears.  Think a computer crash reset a bunch of settings.  Any way to get dialog boxes back?  Can't find it in "options"...
207 Kudos
Post 2 of 8
Re: No layer properties dialog box
04-29-2011 03:47 PM in reply to: EBHShawRedMt
With out know what version and system specs start with the starndard fixes.
Filedia = 1
Cmddia =1
Murph
Supportting the troops daily.
Member
0 Kudos
Post 3 of 8
04-29-2011 03:54 PM in reply to: Murph
Sorry - PC, Windows 7.  Map 3d 2012.  Already tried those settings - they were set to 1.  Still doesn't work.
207 Kudos
Post 4 of 8
04-29-2011 04:00 PM in reply to: EBHShawRedMt
LAYERDLGMODE
Is it all palettes that fail to display or just the layer property manager palette?
If it's all the palettes (properties, Xref, SSM etc) then it might be a dot net framework issue.
Murph
Member
0 Kudos
Post 5 of 8
04-29-2011 05:25 PM in reply to: EBHShawRedMt
It's the dialog box itself.  No dialog box.  The individual commands pop up next to the cursor in a list, just as if you had typed pedit in the command line.  There is no dialog box.  THink I need to reinstall Autocad...
0 Kudos
Post 6 of 8
05-04-2011 06:33 PM in reply to: EBHShawRedMt
Try this:
1. Press Alt and the Spacebar at the same time, and then let go
2. Press the letter M
3. Press the UP arrow
4. Move your Mouse around and you should see the dialog. Click for the dialog to stay.
Hope this helps.
Original post by Matt Kolberg in 2009
Member
0 Kudos
Post 7 of 8
05-05-2011 06:05 PM in reply to: EBHShawRedMt
Had already tried that one - good news is somehow the installation had been munched.  Reinstall solved everything.
Thanks for all the help.
New Member
0 Kudos
Post 8 of 8
07-19-2012 01:52 PM in reply to: EBHShawRedMt
I had the same problem and tried the same solutions (except reinstall) with no luck.
What worked for me was changing my saved workspace to one that had the dialog box open.
So far so good.
