AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
No label drag state
2 REPLIES 2
annw2
251 Views, 2 Replies
No label drag state
Once I got the labels to show up, I tried to grip edit / drag the label down into the view port so it would plot.  It vanished instead.
How come you have a drag state for Civil 3d labels but not Map one?
I also managed to have other labels vanish as I tried other convert to text and other functions.
Ann Wingert, P.E.
2 REPLIES 2
parkr4st
in reply to: annw2
Labels from what source, process?  How are you converting?
annw2
in reply to: parkr4st
Connect to shp file with Map
style manager - remove fill, change line color, add label with function to concat multiple data fields into one label.
Have label show up at centroid location.  Try to select label to move it.  Have it vanish instead.
Civil 3d 2014.
I tried the Map convert label to AutoCAD text, but the text still shows up as a function in the map workspace.  If you uncheck, it vanishes.  I finally managed to WBLOCK it out to another file. But not all the database objects had labels.  It is a start.
Ann Wingert, P.E.
”Boost
