AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
No extent in drawing
15 REPLIES 15
Message 1 of 16
cedwards8511
2492 Views, 15 Replies
Has anyone got an err like this before?
My Zoom Extents isn't working right and when I try to plot it says, "No extents in drawing. Could not set plot area to Extents." If I hit OK and go to the Plot Window, Extents isn't an option for the Plot Area and the Plot Scales are way off.
I have never seen a drawing that didn't have an extents?
Any suggestions?
15 REPLIES 15
Message 2 of 16
in reply to: cedwards8511
What is returned when you type in EXTMIN and EXTMIN ?
Are you in model space or paper space? On a Layout tab or the model tab?
Murph
The world is not FLAT so why is your GIS data?
http://map3d.wordpress.com
wrote in message news:5766254@discussion.autodesk.com...
Any suggestions?
Message 3 of 16
cedwards8511
Someone solved the problem for me.
I don't really understand what happened, but it was fixed by going into all of the layouts, making sure they were set to paper space, and zooming to the extent. After I did that to all 30+ layouts, the zoom extent worked fine in the Model Layout.
Thanks for your help.
Message 4 of 16
cedwards8511
When I Zoom Extents, it goes way too far out, way past anything that is drawn in. Like out to the entire world when all I want and have is one town.
Command: extmin
EXTMIN = -1.00E+20,-1.00E+20,-1.00E+20 (read only)
Command: extmax
EXTMAX = 1.00E+20,1.00E+20,1.00E+20 (read only)
Message 5 of 16
edwa8511
I have a dwg that when I Zoom Extents, it also goes too far out.
I have tried all of the trick that typically solve this (Erasing all but the selected objects, Audit, Purge) and even stripped everything out of the drawing one thing at a time and didn't find anything.  There is nothing left in the dwg and it sill does it.
The odd thing is that now when I enter Erase All, it says:
3 found
3 were filtered out
There seems to be three objects in this dwg that I cannot select/read/edit.  Also, when I open the Design Center, there are a bunch of blocks (looks like tick, arrows, and some text blocks) that I can't get rid of.
This is not a dwg that I can just Wblock and create a new file, because there are many database connection, custom visual settings, layouts, etc. that I don't have the time to recreate.
Any Suggestions?
Message 6 of 16
Alfred.NESWADBA
in reply to: edwa8511
you have 3 non-graphical entities in the modelspace:
MAPBULKFEATURE, MAPGISLABES, MAPGISLAYERBITMAP ... these are all Map3D-objects and yes, you are right, you can't delete them with _ERASE.
What you can do:
save this drawing as DXF file
open the DXF file with an ascii-editor (e.g. Notepad++, Notepad would also be possible, but a little bit slow)
search for the part:
  0
SECTION
  2
ENTITIES
 0 MAPBULKFEATURE 5 131117 330 17
 And start erasing at the red marked lines up to this part:
100 AcMapGisLayerBitmap 70 1
  0
CIRCLE
  5
22DC03
330
17
100
then save the file and open it with AutoCAD. ==> now ZoomExtents works.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 7 of 16
I love this Cad "surgery", Herr Alfred.. Wuenderbar!
Message 8 of 16
and getting your answer (thank you) I saw that the formating of the red part of the DXF (the lines to be erased) where reformatted in a way that is wrong, sorry for that! (and now I can't modify that ;( )
@edwa8511:
Please compare the lines between your DXF and my attachment!
- alfred -
Alfred NESWADBA
Message 9 of 16
edwa8511
in reply to: Alfred.NESWADBA
This worked great on the stripped down dwg, but the original with all of its complexity is causing problems when trying to reopen the .dxf in CAD.  It keeps crashing.
When I save the dwg to a dxf, I got it to open it before I edited it.  If I try to open it after making your changes, CAD shuts down.
I am trying to edit the dxf with Notepad, is there something better to use?
Message 10 of 16
Alfred.NESWADBA
As mentioned, Notepad is not built for large files, try Notepad++ instead, downloadable >>>here<<<
- alfred -
Alfred NESWADBA
Message 11 of 16
edwa8511
I have installed Notepad++, I am amazed that I didn't need IT for that..Thanks.
I opened the dxf and tried to delete those lines, but when I try to open it in CAD, I get:
The following error was encountered while reading
in SEQEND starting at line 828316:
Premature end of object
Invalid or incomplete DXF input -- drawing discarded.
I don't know enough about this language to understand what the problem is.  I didn't start editing until line 828325.
Message 12 of 16
Alfred.NESWADBA
it's hard to say what you did or what is wrong with this part of the DXF-file.
At least you have a line-number and I would first look to this line ... plus a few lines above and below. Of course I understand that replacing parts of the file needs knowledge about how DXF is structured. Deleting one line on the wrong place can cause big troubles and in most cases the DXF is then not readable anymore.
Can you upload this DXF (zipped)?
- alfred -
Alfred NESWADBA
Message 13 of 16
edwa8511
I don't know if I got this small enough to attach, but I will give it one more try.
I really appreciate your help..Thanks.
Message 14 of 16
Alfred.NESWADBA
find attached a version, that does ZoomExtents like it should. Please verify first all your dataconnections before deleting your previous file!
- alfred -
Alfred NESWADBA
Message 15 of 16
edwa8511
You Are The Man...
That's Great.
Did you have to do anything different than what you had explained to me earlier?  I have at least one other drawing with the same problem and will try to fix them later.
Thanks for all the help.
Message 16 of 16
Alfred.NESWADBA
No;)
- alfred -
Alfred NESWADBA
”Boost
