AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
no dialog boxes (and both cmddia and filedia = 1)
2 REPLIES 2
2921 Views, 2 Replies
Hi.
Is there a known solution for the problem below?
I'm experiencing the same.
Thanks in avance.
Felipe.
George Anderson escreveu na notícia de
mensagem <3B6720F6.2C64D69A@eweb.eugene.or.us>...
> I sure hope someone can point me toward the variable I can not seem to
> find.
> No dialog boxes are being presented from picks on the Map toolbar.
> Attach, Object Data, if I select it I get a command line response.
> AutoCAD toolbar picks like hatch present a dialog box but nothing from
> either Map toolbar.
> I've double checked cmddia and filedia. Both are set to 1. Is there a
> variable I'm missing that effect the Map commands specifically?
> Please hurry, I want my dialogs back.
> Thanks in advance,
> George
2 REPLIES 2
And expert (another system variable) = 0 ("all prompts are issued
normally").
I suspect it is some ACADMap's setting.
Any hint?
Felipe.
Felipe Nievinski escreveu nas notícias de
mensagem:918FC57D07C697EE509CA9C7EC38E4D4@in.WebX.maYIadrTaRb...
> Hi.
> Thanks in avance.
> Felipe.
> > find.
> > either Map toolbar.
> > Thanks in advance,
> > George
It looks like your Tools-->options->support paths are not properly set.
Click on Tools-->Options-->File Tab
Click on 'Support File serch path' tree node click on add and enter the
full path where support directory is located from your map installation
directory.
For example on my system
D:\Program Files\AdeskMap5\support
D:\Program Files\AdeskMap5\fonts
D:\Program Files\AdeskMap5\help
Make sure you have above entries and close the Map and start the Map again.
Hope this helps.
Ramana
"Felipe Nievinski" wrote in message
news:ABF09BA4D263CCB5F0E3484BE6774035@in.WebX.maYIadrTaRb...
> normally").
> Any hint?
> Felipe.
> > Hi.
> > Thanks in avance.
> > Felipe.
de
> > > find.
> > > either Map toolbar.
a
> > > Thanks in advance,
> > > George
”Boost
