AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
New Map background color in AutoCAD Map 2013...
4 REPLIES 4
1114 Views, 4 Replies
Don't works for me. I have changed this new property for some Maps but AutoCAD Map always displays the default background color that I set up in AutoCAD Options. Any trick?
Thanks in advance
4 REPLIES 4
phil_borycens
Can you please reply with a set of steps to reproduce this issue?
Thanks!
Phil
Phil Borycens
in reply to: phil_borycens
Hi Phil, thank you for your answer
See attached Video
phil_borycens
Thank you for the video.
I tested this myself, and replicated the issue on my system. It appears that the background color assignment is not respected by the program after creating a new display map, assigning a background color to it, and associating it with a viewport.
I did some research internally, which led me to find out that our development team has been investigating this issue. The good news is that they have developed a codefix to resolve this issue. This fix, unfortunately, is planned for release in a future service pack, and I do not have information regarding if/when this service pack might be released.
I have linked your case to the change request for the issue, which will bring further attention to it.
Thank you for reporting the issue to us.
Phil Borycens
Hi. Any news about that? Same problem in AutoCAD Map 2014. Thanks
”Boost
