AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
New database and shapefiles creation
1 REPLY 1
297 Views, 1 Reply
I have started a new project and would like to use the database table from a previous project with this one. Basically what I want to do is create a new shape file using the a previous database table so I do not have to create a whole new data base. I need some help please
1 REPLY 1
phil_borycens
Hi Allen,
That shouldn't be hard at all, in fact, it's quite simple to clone a geospatial database schema. This process, along with an optional data migration (Bulk Copy) is explained in the following document:
How to add or edit fields in SHP or SDF
http://usa.autodesk.com/getdoc/id=TS21941144
I hope that helps and take care!
Phil Borycens
”Boost
