AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
NeuraLog Problem
1 REPLY 1
319 Views, 1 Reply
NeuraLog Problem
Good Morning!
I have been digitizing geophysical logs using the NueraLog program and creating a DXF of the finalized geophysical log.  When I import the DXF into CAD, my data is not there, my curves are just a single straight line.  Any ideas on what could be happing?  I'm currently working with NueraLog because I think this is a problem on their end, but figured I would ask here too!
Thanks in advance!
Tags (2)
1 REPLY 1
Murph_Map
The DXF format is not the best way to handle attibuttes and data. Try to export the info from NeuraLog to shp (ESRI Shape) foramt and import that into MAP3D with Object data or use data connect to bring in the shp file(s).
Murph
Supporting the troops daily.
”Boost
