Good Morning!
I have been digitizing geophysical logs using the NueraLog program and creating a DXF of the finalized geophysical log. When I import the DXF into CAD, my data is not there, my curves are just a single straight line. Any ideas on what could be happing? I'm currently working with NueraLog because I think this is a problem on their end, but figured I would ask here too!
Thanks in advance!
The DXF format is not the best way to handle attibuttes and data. Try to export the info from NeuraLog to shp (ESRI Shape) foramt and import that into MAP3D with Object data or use data connect to bring in the shp file(s).
