AutoCAD Map 3D General Discussion
Member
jchensley
Message 1 of 5 (1,312 Views)
Need Help with GEOMAP Command
1312 Views, 4 Replies
05-06-2013 07:01 AM
I've been attempting to use the GEOMAP command to bring satellite imagery into one of my maps.  I have followed theses steps:
1.  Signed into my Autodesk360 account.
2.  Assigned a coordinate system (SC83F) to my map.
3.  Entered the GEOMAP command and selected "A" for aerial image.
Following these steps, I am unable to display the aerial imagery.  Is there a setting or an additional step that I am missing here?  Thanks for the help.
Member
dipalikasunde3
Message 2 of 5 (1,201 Views)
Re: Need Help with GEOMAP Command
06-24-2013 08:29 PM in reply to: jchensley
Geomap command will display data in a limited area (based on the assigned coordinate system). To view the data you will require to zoom in For example, Assigned coordinate system WGS84 43N (this CRS is suitable for data between 72°E and 78°E, northern hemisphere) in this case, zoom in to the area between the given coordinate (72E and 78E). On doing so, you will be able to view the image data.
New Member
ncarroll
Message 3 of 5 (600 Views)
02-21-2014 02:20 AM in reply to: dipalikasunde3
I've the same issue that reply is nonsense
braudpat
Message 4 of 5 (587 Views)
02-21-2014 08:24 AM in reply to: jchensley
Hello
Please you are where exactly with this SC83F projection ?
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
Murph
Message 5 of 5 (575 Views)
02-21-2014 03:46 PM in reply to: braudpat
braudpat wrote:
Hello
Bye, Pat
My guess is in the USA, South Carolina, seeing I use TN83F for Tennessee.
Murph
Supportting the troops daily.
