AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Need Help with GEOMAP Command
12 REPLIES 12
Message 1 of 13
2451 Views, 12 Replies
I've been attempting to use the GEOMAP command to bring satellite imagery into one of my maps.  I have followed theses steps:
1.  Signed into my Autodesk360 account.
2.  Assigned a coordinate system (SC83F) to my map.
3.  Entered the GEOMAP command and selected "A" for aerial image.
Following these steps, I am unable to display the aerial imagery.  Is there a setting or an additional step that I am missing here?  Thanks for the help.
12 REPLIES 12
Message 2 of 13
Geomap command will display data in a limited area (based on the assigned coordinate system). To view the data you will require to zoom in For example, Assigned coordinate system WGS84 43N (this CRS is suitable for data between 72°E and 78°E, northern hemisphere) in this case, zoom in to the area between the given coordinate (72E and 78E). On doing so, you will be able to view the image data.
Message 3 of 13
ncarroll
I've the same issue that reply is nonsense
Message 4 of 13
braudpat
Hello
Please you are where exactly with this SC83F projection ?
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 5 of 13
Murph_Map
in reply to: braudpat
@braudpat wrote:
Hello
Bye, Pat
My guess is in the USA, South Carolina, seeing I use TN83F for Tennessee.
Murph
Supporting the troops daily.
Message 6 of 13
dtrimble
We are having the same issue in our office where, in the past, Geomap worked fine but now none of our three software seats can access the imagery.
Coord sys assigned and A360 account looged on.
Message 7 of 13
Murph_Map
in reply to: dtrimble
Have you installed the hotfix for the Bing Maps?
Murph
Message 8 of 13
dtrimble
in reply to: Murph_Map
Roger that!
Ver 20.0.210.0.3
Message 9 of 13
The hotfix did the trick for us. Works great now.
Craig Hensley
Mobile: 706-889-4220
Message sent from a mobile device. Please excuse typos or brevity.
Terracon provides environmental, facilities, geotechnical, and materials consulting engineering services delivered with responsiveness, resourcefulness, and reliability.
________________________________
Private and confidential as detailed here (www.terracon.com/disclaimer). If you cannot access hyperlink, please e-mail sender.
Message 10 of 13
dtrimble
Forgot to say that the Hotfix has not fixed our problem
Message 11 of 13
Murph_Map
Sign out of A360 from the Windows task bar, then make sure when you use the GEOMAP command make sure you get the A360 Sign In dialog box.  You may need to go to the Options (In AutoCAD MAP3D) System tab and select the Hidden Message box.
Do you have an object in the map before trying to bring in the images?
Murph
Message 12 of 13
dtrimble
Ok I signed out and then back in.
Yes I alway have something in my file before I use geomap and I do zoom in quite a bit
This was the result.
If I zoom in or out all the imagery goes away.
Message 13 of 13
dtrimble
Cant say why but...
After a Windows update, a reboot, sign out and then sign back in to 360....VIOLA! I have imagery!
Thanks for the help
”Boost
