AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Need help with feature label if/then expression
3 REPLIES 3
ryder1250
650 Views, 3 Replies
I'm trying add a feature label to a polygon feature with an if/then expression that will display the NAME field only when the STATUS field = A.  I'm kind of new to this so haven't been able to figure an expression out.
3 REPLIES 3
parkr4st
in reply to: ryder1250
select the layer in display manager
style
add a rule  STATUS  = A
Feature Label  set to   Name
leave the default without a label
you can also set the style to a different fill(s)
ryder1250
Great... Thanks!!!
parkr4st
Great and now save it as a .layer file for future reference
dave
”Boost
