Well, i´ve got two problems:
1. The FDO for mySQL doesn´t work, so i use an ODBC FDO and that works (
hope, because i haven´t a geodatabase in mySQL and can´t load anything. But
it connects to the database and show the schema of a not-geodatabase ). I´d
like to KNOW WHY, if it´s a problem in my installation or what...
2. I can use mySQL database as data origin, linking with objects but the
data viewer only opens as read-only, so the only way to write in the linking
tables is entering the data inside property palette. It´s a paradox,
because if you link objects to a data origin ( not as feature ) and you
enter data in property palette, then you CAN ENTER DATA inside the mySQL
tables. Then, WHY the data viewer opens as READ ONLY?
When i have time, i´ll start to desinstall, play with other mySQL versions,
etc.. 😞
lyapunov
