AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MrSID load in Map 2010
4 REPLIES 4
HuskerT
595 Views, 4 Replies
I would like to load a MrSID file (MG2 format) in 2010 as an image so I can clip it.
Is this possible?
4 REPLIES 4
sbarber
in reply to: HuskerT
You just need to load the free raster design program from autodesk to beable to load MrSid file in regular Acad 2010.
Good Luck,
Scott
mvilla724
download the Object Enabler from Autodesk.com. after that you can use the 'mapiinsert' command and let'r go.
HuskerT
Thank you, Scott.
I finally got it to work.
Appreciate the help!
HuskerT
Thank you, Mr. or Ms.,
I appreciate the response!
”Boost
