AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Mpolygons
10 REPLIES 10
Message 1 of 11
mstacey82
543 Views, 10 Replies
Mpolygons
My AutoCAD (MAP 3D 2009) has somehow lost the ability to recognize the properties of mpolygons. Before, I could change the outline color and the fill color from the properties window, but now, when I select an mpolygon that I created, its as if I clicked on nothing, as nothing appears in the properties window. I did install AutoCAD Map 3D 2010 and Raster Design 2010 recently, and noticed the problem soon after, but I have since uninstalled them both, and did a new re-install of Map 3D 2009, but the problem with the mpolygons continues. I have looked for existing answers on the internet but have come up empty. Does anyone out there have any suggestions for me? Any help would be greatly appreciated. Thanks!
Mike
10 REPLIES 10
Message 2 of 11
in reply to: mstacey82
Type PICKFIRST at the command line and set it to 1.
Murph
http://map3d.wordpress.com/
"mstacey82" wrote in message news:6332986@discussion.autodesk.com...
Mike
Message 3 of 11
mstacey82
Hey Murph,
just tried that, and it was already set to 1. Tried 0 as well, no results. Thanks though.
Mike
Message 4 of 11
If you select any other object does the property palette work OK?
Murph
Mike
Message 5 of 11
mstacey82
Yes. I made polylines, rectangles, circles, hatches and they all show up normally in the properties window. To my knowledge, mpolygons are the only object type that won't show up.
Mike
Message 6 of 11
It's not on a locked layer is it?
Murph
"mstacey82" wrote in message news:6333010@discussion.autodesk.com...
Mike
Message 7 of 11
mstacey82
Nope. I started a fresh drawing, with only layer "0". I drew a polygon and converted it to an mpolygon. I also drew a polyline and a circle, all on layer 0, and when I select all of them, it does show that 3 objects are selected, but from the pull down in the properties window, only the polylines and circle are visible. I also tried creating these objects on a new layer, but get the same results. I've attached a jpeg to show what you see when you select the mpolygon, polyline and circle all at once.
Mike
Message 8 of 11
Attach that dwg and I'll look at it.
Murph
"mstacey82" wrote in message news:6333015@discussion.autodesk.com...
Mike
Message 9 of 11
mstacey82
Here it is. If you autocad works properly, you shouldn't have any issues.
Message 10 of 11
Works OK in 2009 with RD and in 2010 for me.
Might want to try a clean uninstall and reinstall.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Murph
"mstacey82" wrote in message news:6333061@discussion.autodesk.com...
Message 11 of 11
mstacey82
Yeah, I might just have to do that I guess. Thanks for you help. Much appreciated.
Mike
”Boost
