AutoCAD Map 3D General Discussion
Valued Contributor
frosty1_4me
Message 1 of 7 (294 Views)
MPOLYGON fills on close
294 Views, 6 Replies
02-21-2014 08:51 AM
There are some issues with MPOLYGONs and the fill that is applied when they are closed.  I can turn off that behavior by setting FILLMODE to '0' when creating those objects but that does not help me to address legacy MPOLYGONs that already have the fill applied.  And if a user forgets to turn the FILLMODE back on, when creating PLINES with width those too will lose their fill.
This was not an issue in MAP3D 2011, but I'm not sure when this behavior was changed.  It's certainly not ideal.   Being able to set the hatch pattern to NULL for the MPOLYGON type objects would be much better.
Is there a fix for this?
Valued Contributor
frosty1_4me
Message 2 of 7 (283 Views)
Re: MPOLYGON fills on close
02-21-2014 10:41 AM in reply to: frosty1_4me
I have tried the polydisplay command but it does nothing even after regen.
Valued Contributor
Gary_Braun
Message 3 of 7 (276 Views)
02-21-2014 12:24 PM in reply to: frosty1_4me
FILLMODE should work. Have you tried a regen after toggling it on or off?
Murph
Message 4 of 7 (268 Views)
02-21-2014 03:44 PM in reply to: frosty1_4me
Set the MPFILL to TRANS from the Other Predefined tab. The TRANS stands for Transparency. You can use Quick Select and select the current ones and then change the fill patterned from the properties palette. The PolyDisplay only works on newly created mpolgons.
Murph
Supportting the troops daily.
Valued Contributor
frosty1_4me
Message 5 of 7 (257 Views)
02-23-2014 09:29 AM in reply to: frosty1_4me
Thanks Murphy, I'll give that a try. The fill mode affects all objects with fill, not what I'm after.
I'll let you know how it works out.
Valued Contributor
frosty1_4me
Message 6 of 7 (237 Views)
02-24-2014 08:17 AM in reply to: Murph
I tried the MPFILL but the TRANS that is listed shows a pattern and isn't transparent.   The polydisplay even when creating new MPOLYGONS does nothing and the MPOLYGON that is created after setting the polydisplay to Edge only still fills in solid.
Any other thoughts around this?
Thanks.
braudpat
Message 7 of 7 (232 Views)
02-24-2014 10:26 AM in reply to: frosty1_4me
Hello
My suggestion : to have almost transparent MPOLYGON, I am using (since 12 years) the DOT pattern with a huge Scale = 99999  so I get (on the screen and on the paper after printing) only a small Dot somewhere in the MPolygon, but I don't care ...
History : MPOLYGON began with an optional module to install on MAP R5 based on ACAD 2002 ...
MPOLYGON have been included in the Kernel of MAP with MAP R6 always based on ACAD 2002 !
As far as I know, a few IMPORTANT things are missing to the "famous" MPOLYGONs of MAP :
- a REAL transparent pattern
- a LineWeight for the hatch pattern DIFFERENT from the general LineWeight
- a LineType for the hatch pattern DIFFERENT from the general LineType
Bye, Pat
Bye, Pat
