So what's the deal with the projection stuff?
Running AutoCAD 2000i on an NT workstation.
In VBA first I attempt to change the projection
of the current project through accessing the project object in VBA.
That causes a "bad method on object" error. I tried to skirt the
issue by setting up a template dwg with the projection I want. I
interactively open a new dwg using my template, check the projection
and all is well. I then programmatically open a new drawing using
the template and no projection is set. Could it have something to
do with MDI?
Requesting any assistance. If I cant programmatically
modify projections I'll be forced to go back to using ArcInfo...
OOPS, did I say that out loud?
Keath
