AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
More projection problems!!!
0 REPLIES 0
Message 1 of 1
136 Views, 0 Replies
So what's the deal with the projection stuff?
Running AutoCAD 2000i on an NT workstation.
In VBA first I attempt to change the projection
of the current project through accessing the project object in VBA.
That causes a "bad method on object" error.  I tried to skirt the
issue by setting up a template dwg with the projection I want.  I
interactively open a new dwg using my template, check the projection
and all is well.  I then programmatically open a new drawing using
the template and no projection is set.  Could it have something to
do with MDI?
Requesting any assistance.  If I cant programmatically
modify projections I'll be forced to go back to using ArcInfo...
OOPS,  did I say that out loud?
Keath
0 REPLIES 0
”Boost
