i have a file with a bunch of blocks that show the text description for data is attached to them. Is there a way to modify them so that they do not show the info but still have the data attached to the block?
Solved by Murph_Map. Go to Solution.
Freeze layer "Raw-Desc"
- alfred -
"Attdisp" "OFF", A regen may be required. To show them again ATTDISP on.
works perfect without having to turn layers off. anyone can do a simple turn off layers
