I have an existing point style that has several thematic rules. When I "Add a Rule" it does not save and the next time I open the drawing, the rule is gone. Any help? Map3d 2013 on 64 bit PC windows 7
Solved by davidm889. Go to Solution.
never had such a problem. What happens if you add a new rule and after that export that as .LAYER file and reimport it into a new drawing.
Just to make sure (sorry) ... you have saved the drawing after adding the rule?
- alfred -
After much tinkering, and yes I did save the file :), I decided to install 2014 and it works fine now. I guess it was just telling me to install my upgrade!!!! 🙂
