AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
modifications to point style not saving
2 REPLIES 2
davidm889
402 Views, 2 Replies
I have an existing point style that has several thematic rules. When I "Add a Rule" it does not save and the next time I open the drawing, the rule is gone.  Any help? Map3d 2013 on 64 bit PC windows 7
2 REPLIES 2
Alfred.NESWADBA
in reply to: davidm889
never had such a problem. What happens if you add a new rule and after that export that as .LAYER file and reimport it into a new drawing.
Just to make sure (sorry) ... you have saved the drawing after adding the rule?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
davidm889
After much tinkering, and yes I did save the file :), I decided to install 2014 and it works fine now. I guess it was just telling me to install my upgrade!!!!  🙂
”Boost
