AutoCAD Map 3D General Discussion
Active Contributor
KrakowiAneczka
Message 11 of 12 (190 Views)
Re: missing text when plot
01-19-2012 03:00 PM in reply to: Alfred.NESWADBA
Yes, yes, yes...I know....but on the other hand I'm pretty sure the update does not fix floating text issue :smileywink:
" creating a point-topology from the labels in the SHP" - how to do that?
I was converting lables to text but for some parcels text is not created.
Alfred.NESWADBA
Message 12 of 12 (189 Views)
01-19-2012 03:07 PM in reply to: KrakowiAneczka
Run command _MAPIMPORT4 ==> for a polygonal shape this creates 2 objects for each polygon:
a) closed polylines as the border
b) an AutoCAD-point (guaranteed inside the polygon, even in critical island situations) describing the attibutive data within object-data-tables. For you this point is the position of the label,
You can then do _MAPEXPORT just of the points (including export of the object data table) to get a SHP with position of the label + attributive data.
- alfred -
Alfred NESWADBA
