AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
missing Shp polygons in Map3D
4 REPLIES 4
roycee
322 Views, 4 Replies
When i load my shp parcel data into Map3D some of the polygons are gone. I can view some of it but when i zoom in it disappear!! Consequently i can not select it to edit or use it.
I guess this problem is similar to craigintx's problem:
Problems converting closed polylines to polygons
Posted by: craigintx
Date: Jun/27/08 - 23:46 (HKT)
I created closed polylines from old linework for GIS use. I now have building outlines with attached object data. I need to convert to polygons, but when i try various methods, only about 80% of the outlines can be converted. I have a similar problem with SDF, but different outlines are affected. Does anyone have an idea what could be causing this?
HELP!
4 REPLIES 4
roycee
in reply to: roycee
Additional info:
Although some of the polygons can't be seen when i zoom in or out or pan, some can still be selected. While some i just can't select.
in reply to: roycee
Are you using th FDO provider to load your Shapefile Polygons or are
importing them in. The FDO provider still has a few bugs. If I remember
correctly, I think someone posted a similar problem when using the FDO
connection. I believe the fix was to use the standard import.
Tripp Corbin, MCP, CFM, GISP
Vice President, GIS/IT
ESRI Authorized Instructor
Keck & Wood, Inc.
(678) 417-4013
(678) 417-8785 fax
wrote in message news:5970438@discussion.autodesk.com...
Additional info:
caddesk2000
in reply to: roycee
I had this issue as well. I did a standard mapimport of the polygons in question, then re-exported to a new shape file and the problem was fixed.
Sam
roycee
in reply to: roycee
I am using FDO provider to load shp. Thanks for the heads up on the bugs. Also tried importing them and it also produced problems.
I am not sure if the problem was the version of ArcView (3.2) i initially used to create the polygon. Tried using a different version (3.3) and the disappearing polygons worked.
Thank you for the replies.
”Boost
