AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Missing Annotation panel under Block Editor tab
5 REPLIES 5
nik.mazreen
3244 Views, 5 Replies
i noticed that AutoCAD Map 3D 2015 is missing Annotation panel under Block Editor tab. Is it because its no longer exist or am i missing something during the installation?
Appreciate the help.
Thanks in advance.
Rgds,
Nick
5 REPLIES 5
rsniff
in reply to: nik.mazreen
Courtesy of Autodesk Help.
  1. On the command line, type cui Enter
  2. In the “Customizations in All Files” panel expand “Ribbon<Tabs<Block Editor Contextual Tab”
  3. Scroll down to the end of the “Tabs” Section
  4. Expand the “Panels” section
  5. Scroll down to “Annotate – Block”
  6. Left click on “Annotate – Block” and drag up into the “Tabs” section and drop in between “Block Editor – Action Parameters” and “Block Editor – Visibility”(the section you expanded in step 2)
  7. Click “Apply” and “OK”
Pointdump
in reply to: rsniff
R,
I'm stumbling here on Step 2. I can't find "Block Editor Contextual Tab".
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
Alfred.NESWADBA
in reply to: Pointdump
look to >>>that thread<<<, Phil had created a video showing how to get the menu item back.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Pointdump
in reply to: Alfred.NESWADBA
Alfred,
Thank you. With the help of the video I figured out why I couldn't find it. I was looking in the CUI of Civil 3D. When I open up Map I can find it. So I'm going to add it in Map, but I probably won't be able to use it in C3D. Oh well.
Dave
Dave Stoll
Las Vegas, Nevada
Pointdump
OK I found it. Doug showed the way in <<This Thread>>
It's buried deep in the Partial Customization Files. Very deep. Pack a lunch.
Dave
Dave Stoll
Las Vegas, Nevada
”Boost
