AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Migrating settings from 2012 - 2013 Autocad Map 3D error
2 REPLIES 2
691 Views, 2 Replies
i installed Autocad map 3d 2013 Version, and works fine but  then i did migration settings from 2012.
apparently migrations works fine but give me an error message.
Errors
CUI: Error encountered migrating CUI file - pdfic.cuix could not be found.
CUI: Error encountered migrating CUI file - pdfmacad.cuix could not be found.
then when i open 2013 Version Autocad show me an error message and then log me out system.
i attached errors messages.
any help will be appreciated.
thank you.
2 REPLIES 2
NateMoore
It sounds a little different, but you might find http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20156032&linkID=9240858 helpful.
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
in reply to: NateMoore
Thank you was very helpfull
”Boost
