AutoCAD Map 3D General Discussion
New Member
rafaelgarcia
Message 1 of 3 (432 Views)
Migrating settings from 2012 - 2013 Autocad Map 3D error
432 Views, 2 Replies
09-25-2012 09:45 AM
i installed Autocad map 3d 2013 Version, and works fine but  then i did migration settings from 2012.
apparently migrations works fine but give me an error message.
Errors
CUI: Error encountered migrating CUI file - pdfic.cuix could not be found.
CUI: Error encountered migrating CUI file - pdfmacad.cuix could not be found.
then when i open 2013 Version Autocad show me an error message and then log me out system.
i attached errors messages.
any help will be appreciated.
thank you.
It sounds a little different, but you might find http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20156032&linkID=9240858 helpful.
Product Support
NateMoore
Message 2 of 3 (421 Views)
Re: Migrating settings from 2012 - 2013 Autocad Map 3D error
09-25-2012 11:53 PM in reply to: rafaelgarcia
Nate Moore, GISP
Geospatial Premium Support Specialist
Global Services
Autodesk, Sarl
New Member
rafaelgarcia
Message 3 of 3 (409 Views)
09-26-2012 09:38 AM in reply to: NateMoore
Thank you was very helpfull
