AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Menu drop downs are THERE but they disappear before I can select anything?
3 REPLIES 3
toney.lowery
352 Views, 3 Replies
Thanks for looking at this post.
My menu pull downs/drop downs disappear before I can select anything. For instance. If i want to change an object's layer I can't get to the layers lower on the list before the drop down disappears. The same for changing hatch patterns. There may be other as well.
I can change the items if I use the Object propoerties panel though.
Any ideas?
Toney
3 REPLIES 3
rkmcswain
in reply to: toney.lowery
What version of what application?
Are these toolbar dropdowns or dropdowns in the Ribbon?
R.K. McSwain     | CADpanacea | on twitter
toney.lowery
in reply to: rkmcswain
oops... forgot the version info...
2015 Map3D, Windows 7
These are tool bar drop downs.
Thanks for asking and letting me clarify.
First at all: does that happen all the time or did it just appear? And ... have you tried to restart your workstation?
Sounds like you have installed a tool on top of AutoCAD that's handling menus or you might have some troubles with your display driver.
I would start with updating the graphic card driver (look also to the >>>certified hardware list<<<).
If you are working on a dual screen system you might also try to move the AutoCAD application window to the other monitor.
And at least a repair installation of Map 3D might help.
Good luck, - alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
”Boost
