AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Match rotation
5 REPLIES 5
506 Views, 5 Replies
Match rotation
A few version ago autocad had a function that would allow you to pick one
line and match the same bearing to any other line you selected. My question
is does this function still exist and if so, how can I do it?
Autocad Map 2007
5 REPLIES 5
would that be the ALIGN command?
Melanie Perry
***not all who wander are lost***
http://mistressofthedorkness.blogspot.com/
"Jason Heyman" wrote in message
news:5468603@discussion.autodesk.com...
Autocad Map 2007
IIRC it was an old express tool, that got dropped when Matchproperties was
ported into the core AutoCAD. The closes thing to it is using the properties
palette and quickcal with an expression.
Murph
The world is not FLAT so why is your GIS data?
http://mappingitout.blogspot.com/
"melanie stone" wrote in message
news:5468654@discussion.autodesk.com...
Melanie Perry
Autocad Map 2007
No, this was just a simple express tool where you could just click a line
and every other line you selected would match the same bearing. Align is not
really what I am looking for.
Melanie Perry
Autocad Map 2007
in 2006 at least the Align command is to be found under the Modify menu.
well, that's goofy... it's under Modify > 3D Operation (but the prompt in
the taskbar says 2d and 3d alignments)
Melanie Perry
"James Murphy" wrote in message
news:5468664@discussion.autodesk.com...
Murph
Melanie Perry
Autocad Map 2007
right. sorry. that one would give it the same angle, but, would physically
move it and you don't want that.
Melanie Perry
news:5468688@discussion.autodesk.com...
Melanie Perry
Autocad Map 2007
”Boost
