AutoCAD Map 3D General Discussion
Active Contributor
smvest
Message 1 of 4 (356 Views)
marking overlapping lines
356 Views, 3 Replies
07-31-2012 01:00 PM
I need to find lines that overlap one another in a drawing and mark them, not delete them.  I am running AutpCAD Map 3D 2012.
~Sue
Product Support
phil_borycens
Message 2 of 4 (337 Views)
Re: marking overlapping lines
08-01-2012 02:31 PM in reply to: smvest
Hi Sue,
Thank you for posting to the Autodesk Discussion Groups.
I would like to help you, but unfortunately, I do not understand your request.
Can you please reply with a detailed problem description that includes a set of steps to reproduce? Screenshots might help too.
Thanks!
Phil
Phil Borycens
Valued Mentor
parkr4st
Message 3 of 4 (329 Views)
08-02-2012 02:38 AM in reply to: phil_borycens
your option if the lines are drawing objects
cleanup tools - find duplicates
if the line are on different layers .  qselect a layer to highlight the line on that layer
shift select and delete one line copy and delete to see the line underneath, cntrl z to replace it.
if the lines are FDO objects open the data table and select each line in the table
post the types of line and details for a better answer
dave
antoniovinci
Message 4 of 4 (325 Views)
08-02-2012 02:43 AM in reply to: phil_borycens
Dear Phil, there's nothing to understand: she simply wanna highlight the ovelapping lines, without deleting them.
Here's my workaround, Sue:
  1. type in _MAPCLEAN
  2. set up like this
  3. in the next window, click on "retain.." and not on the default "modify.." like this
  4. after "Finish", you can isolate the layer SMVEST containing a copy of your overlaps
