AutoCAD Map 3D General Discussion
andras.zelenka
Message 1 of 4 (839 Views)
Maptoacad Mtext export Limitations
839 Views, 3 Replies
02-13-2014 07:00 AM
Hi all!
Recently met an interesting error, when i save my GIS data with maptoacad command. In the layers of the created dwg was only 2000 Mtext, even if the Map layer has more then 2000 labels. As i know, in Map3D we have two different methods to create object labels (Inside the Style Editor):
- The Feature label part: i met with the limitations, only 2000 Mtext created from the labels
(attachment: feature_label.png)
- The Style part: i don't met with the limitations, all Mtext created from the labels
(attachment: style.png)
Any Idea to Solve this 2000 (Label/Mtext) Limitation, without *.layer file manual editing? I need to use the first method to creating labelled Map layers.
Andras
Map3D2013
olivier.eckmann
Message 2 of 4 (830 Views)
Re: Maptoacad Mtext export Limitations
02-13-2014 08:58 AM in reply to: andras.zelenka
braudpat
Message 3 of 4 (824 Views)
02-13-2014 09:54 AM in reply to: andras.zelenka
Hello
+1 with Olivier
Unfortunately it's a very old FDO limitation !
Today with 64 bits PCs, Autodesk could have increased this limtation !! But NO !!!!
Bye, Pat
<<< Old Link >>>
--- OLD --- Increasing maximum number of Display Manager Feature Labels displayed ---
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10408989&linkID=9240857
Published date: 2009-Feb-19  --- ID: TS1077666
Applies to: AutoCAD Civil 3D 2008, AutoCAD Land Desktop 2008, AutoCAD Map 3D 2008
--- Issue --- You want to increase the maximum number of feature labels that can be displayed in your map
<<< End >>>
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
andras.zelenka
Message 4 of 4 (796 Views)
02-14-2014 01:06 AM in reply to: olivier.eckmann
Thank you for your post, Olivier and Pat!
It works great!:smileyhappy:
Andras
