AutoCAD Map 3D Forum
Welcome to Autodeskā€™s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
mapimportfdo - point to block with attribute - attribute on current layer? Why?
4 REPLIES 4
luc.vanlinden
466 Views, 4 Replies
Hi
A block definition with an attribute. The attribute has its own layer. Normal behavior as far as I know is when inserting a block, the block gets inserted on the current layer while the attribute will end up on its own layer. This is as far my experience with plain AutoCAD.
Now when using the mapimportfdo command and mapping point features (from oracle) to blocks it turns out that the block as such ends up to the target layer defined by the mapping specs (so far so good), however the attribute ends up at the current layer at the moment the mapimportfdo command is issued, and not on the layer of the attribute definition, as it does when inserting it in a normal autocad way.
Working with different block/attributes on the import will end up that all different attributes will end up at the same (current) layer.
Why are these attributes not drawn on their proper (definition) layer? Will have to add it to the long issue/inconsistency list of mapimportfdo/mapexportfdo.
Luc
4 REPLIES 4
braudpat
in reply to: luc.vanlinden
Hello from France
- I am a very old user of ACAD : sincre R1.4 in 1984/1985 ...
- I am a very old user of MAP : since ADE module on ACAD R12
and then it was the worst MAP : MAP R1 based on ACAD R13 (the worst ACAD) ...
Historically the MAIN problem with AutoCAD MAP is :
<Humour ON>
- The MAP development Team doesn't speak/collaborate with the ACAD Team
- The FDO development Team doesn't speak/collaborate with the OLD MAP development Team which doens't ...
<Humour OFF>
A lot of things have not been "terminated correctly" with MAP and especially with the FDO Technology !!!
So we have to play with some nice features (like FDO) which needs YET a few improvments / optimisations ...
Why we have not a Grid View of Object Data ?
Why we have not a Quick Select on Object Data ?
Why we can't interact easily between FDO Attributes and Object Data and (only for XYZ Points) with Attributes on Blocks
Of course I don't speak about Dynamic blocks which are not supported ...
etc ...
Why we havn't a better MAPIMPORT / MAPEXORT
and MAPIMPORTFDO / MAPEXPORTFDO ...
Please we need InterOperability (if it's possible) between these differents concepts :
FDO, Object Data, Attributes on Blocks, etc
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Murph_Map
in reply to: braudpat
Can not aruge with any of what you wrote Pat.
Murph
Supporting the troops daily.
braudpat
in reply to: Murph_Map
Hello Murph
What do you say exactly ? (My US/English is not "very good")
Maybe : aruge --> argue ??
Bye, Pat
Patrice BRAUD
Murph_Map
@braudpat wrote:
Hello Murph
Bye, Pat
Yes ARGUE, my spelling error. meaning I agree with everything you wrote in the reply.
Murph
ā€Boost
