AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
Mapexport to new coordinate system PRJ
6 REPLIES 6
BakewellS
1871 Views, 6 Replies
I'm attempting to use mapexport to create ESRI shapefiles for our client's land agents to submit into an Alberta Government GIS database, which requires the use of a specific .PRJ file (no exceptions) as shown here ...
PROJCS["NAD_1983_10TM_AEP_Forest",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-115.0],PARAMETER["Scale_Factor",0.9992],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
Our .dwg files are base in the UTM, NAD83 Datum, CSRS UTM-11N or UTM-12N coordinate systems, and currently we create the shapefiles and then send them to GIS persons and he then corrects the projection in ESRI.  I would hope there would be a way to have our AutoCad presonel to export this file directly from Map3D using the correct .PRJ file, but I have not found a way to import this information into the coordinate lists that are available in Map3D.
Any suggestions?
6 REPLIES 6
BakewellS
in reply to: BakewellS
Additional info, currently using Civil3d 2011.
Jonathan3891
I'm asuming your using AutoCAD Map.
In the MapExport dialog box, on the options tab, you can convert the coordinate system to what ever you like.
Jonathan Norton
Blog | Linkedin
antoniovinci
in reply to: Jonathan3891
I guess that's impossible to import your custom .PRJ in Map, but you can provide its parameters with the ADEDEFCRDSYS command.
In your customer's case, the ADEDEFCRDSYS windows should appear like this...
parkr4st
is that coordinate system   CANA83-10TM115  ?
if it is the list of systems in map 2012.
dave
BakewellS
in reply to: parkr4st
The CANA83-10TM115 is close, but does not have the false easting and slightly different in the mathamatecal parameters...
PROJCS["CANA83-10TM115",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",0.000],PARAMETER["False_Northing",0.000],PARAMETER["Scale_Factor",0.999200000000],PARAMETER["Central_Meridian",-115.00000000000000],PARAMETER["Latitude_Of_Origin",0.00000000000000],UNIT["Meter",1.00000000000000]]
I was hoping that they have made a way to import .prj files (since they are so widely used) into their database of coordinate systems.  I thought I had read that you could somehow automatically register a new system by having it somehow preoaded into a drawing file, but It looks like the previous reply of creating the projection manualy is the only way to do it.  Now my next problem is figuring out which directories to get I.T. to change permissions on, since I am currently unable to create a new system as shown above...
parkr4st
you can modify the existing cs.  by duplicating and modifying
use command mapcscreate   & select the help button.   help explains what you need to modify for the false n & e in
Create Coordinate System   false origin
”Boost
