AutoCAD Map 3D Forum
Welcome to Autodesk’s AutoCAD Map 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Map 3D topics.
MAPEXPORT QUESTION ___text and arcs not to scale___
2 REPLIES 2
334 Views, 2 Replies
Using AutoCAD Map 3D 2012 Im exporting a few subdivisions to MapInfo after doing my steps on a MAPEXPORT command to create a .TAB or .MIF / .MID which are the steps do below.
MAPEXPORT --> select format_ .TAB or .MIF ---> select my drawing manually  ----> do my coordinate conversion -----> DONE..
When in MAPINFO and ready to open / import the exported .TAB it opens and places the drawings (subdivisions) in its correct coordinate I gave it, but the TEXT and ARC / CIRCLES do not come in to scale at all they are extremely large to a point where they can't be seen till I do a zoom all...
How can I fix this ....
2 REPLIES 2
antoniovinci
Ain't Mapinfo to test your issue, but I fear there's no chance to fix it, sir.
As a workaround, before _MAPEXPORTing, try to convert arc/circles to polylines, thru this tool.
in reply to: antoniovinci
I converted the arcs / circles to polylines and it worked when imported to mapinfo. The text on the othe hand still way off scale.
Thanks for the tip!
”Boost
